Like many people, I've been kind of curious how these new mullet bikes ride. I know in theory, the best way to execute it would be as the Bike Mag guys suggest (take a 27.5 bike with a 20mm differential travel, and slap on a 20mm shorter fork up front). I don't have one of those, or even a spare 27.5 rear wheel, so I wasn't planning on pursuing it any further. But last week one of my buddies had a crash that resulted in a broken shoulder, requiring surgery. He rides a Bronson v2, so I asked if I could borrow his rear wheel while he heals up. He said yes, so the Sentinel Mullet Experiment begins.
Base configuration:
medium Sentinel carbon
160mm 44mm o/s Fox 36 fork (with Luftkappe, which causes it to sag a bit)
Push 11.6 shock (sits higher in sag due to 475# spring)
We Are One Agent wheels (30mm internal) with Assegai EXO 3C front and DHR EXO 3C rear (both light wear)
170mm cranks
measured dimensions (using smart phone level & tape measure):
*64.4 degree HTA
*77.9 degree effective STA
*342 mm bottom bracket height
Mullet configuration:
We Are One Agent front wheel (30mm internal) with Assegai EXO 3C Santa Cruz Reserve 27 rear wheel with DHR EXO+ 3C rear (heavy wear)
170mm cranks
*62.9 degree HTA
*75.8 degree effective STA
*333 mm bottom bracket height
I'm going to give it a first ride tomorrow and will report back. Just sitting on it my garage made me notice that the BB is really ****ing low. It's a good thing we don't have a ton of rocks and roots here. What I'm expecting to find is that it will accelerate a bit faster, and the rear end should slide around a bit faster in steep, tight, off-camber turns. Dropping into steeps should feel a bit calmer due to the DH-like HTA.
I'm also going to loan it to the mechanic from my local shop, who is a much better and more aggressive rider than me (but he will have to run the stock DPX2 as he's heavier weight).
Known confounding factors:
*rear tire will be slightly narrower due to narrower rim, will likely slightly decrease grip
*27.5 rear tire tread is significantly more worn than the 29, although they are identical tire model and rubber compound (aside from EXO vs. EXO+). This again will decrease grip.
*the other guy hasn't ridden my bike in regular 29er mode. So all he'll be able to say is whether he likes it better than his HD4.
Base configuration:
170mm cranks
*64.4 degree HTA
170mm cranks
*62.9 degree HTA
