Semi OT : Broken bolt in Sidi....
796 Views 1 Reply 2 Participants Last post by  Trevor!
Checking over my shoes, I noticed a bolt that was sheered off by the head. The clete was firm on the shoe, but it took over an hour to drill/tap out the bolt. Is this common? Did I over torque?
JS
1 - 2 of 2 Posts
JS
Sometimes, depending on what bolt you used, the interface or hole you hex wrench sits in can be quite shallow, and thus if the tool, whilst feeling like it is in all the way, is not, you can sheer the bolt head, or if their is dirt in there then you have the same problem of the tool not getting enough grip and rounding out or sheering the head off. Also general wear and tear can be attributable to broken bolts or indeed over torquing....
Had no such problem with either my Ergo1s or dragons.
1 - 2 of 2 Posts
