Hello all,
I just got an used 07 stumpy, and it came with a 400mm thomson seat post.
If I lower it all the way down is possible (going down over it will hit the shock body) it still gets pretty high, so i definitly need to cut it.
My question actually is: What is the lenght you guys are using on your seatpost at the stumpy 07?
There is a sticker on the frame warning that riding with the seatpost not visible through the seat tube under hole may cause structural problems to the frame.
Is it so?
Cheers!!
Is it so?
Cheers!!
