1 - 9 of 9 Posts
· I Have Gnarly Potential
heya guys, quick question. When ordering a new seatpost clamp, what size do you go by when they ask, the acual seatpost size, or the diamater of the outsize of the tube that the seatpost goes in? (some metal tubes may have diff thicknesses for the same size seatpost i guess)
· Registered
They'll be needing the actual outer diameter of the seattube.
· Faller - Expert Class
Yep, same model, just different size. You could either measure the outer diameter of the seat tube or the inner diameter of the seatpost clamp. "Six in one, half-dozen in the other".:rolleyes:
Hope this helps, you should be set!:cool:
· Derailleurless
Also worth noting that the collar diameter often matches the front derailleur clamp diameter (sometimes that spec is easier to look up online).
When shopping for a replacement, sometimes you'll see collars listed 0.1mm larger than you need. (Salsa does this... a 35.0mm collar yet everyone is looking for 34.9mm). This difference is insignificant and won't affect fit.
Discussion Starter · #7 ·
Very cool :)
· Custom User Title
Man, where was this post a week ago :madman:
1 - 9 of 9 Posts
