I built up a 2021 Canfield Nimble 9 frame as a single speed in June this year. I'm 6' and got the large frame, right in the middle of their recommended range. When pointed downhill, the bike handles like a dream. I've been hitting steep drops and chutes with confidence I never had on my 2016 full suspension trail bike. Double blacks at the park are no problem.
On flat terrain and climbs, it's been a different story. One problem is I feel like I have way too much weight on my hands. After a 5 mile ride, I'm getting moderate wrist and hand pain I've never felt on any of my other bikes. I've played with stem length and rise, saddle position and tilt, and switched out a couple of handlebars. I picked up some SQlab 30X 16 degree bars, which have helped significantly with the pain, but I'm still feel like there's too much weight up front. I suspect this could be a result of the steep seat tube angle, 77 degrees. That's quite a bit steeper than the 73-ish degrees I've had on any of my other bikes. I feel like my weight is too far forward over the cranks to get balanced. Even with the saddle slammed all the way back on the rails, I can't find a position where I'm balanced and not falling forward if I take my hands off the bars.
Somewhat related is that I feel like the saddle is always in the way. With single speed, I'm doing lots of out of saddle climbing on techy rock (St George, think Moab), and the saddle is always digging into my back or taint when climbing tech. It really hinders my ability to move the bike around on trickier obstacles. I can put the dropper down, but that's a hassle to do for every obstacle, especially when I've never felt the need to do that on any of my other bikes. It's also a problem on flat, bumpy terrain. With slacker seat angles, I can set my seat height to get proper leg extension, but there's still enough room to move forward off the saddle a little bit when it gets bumpy to let my legs absorb the terrain. On this bike, if I set the height to get good extension, I can't do the same, because moving forward off the saddle puts way too much weight forward, leaving me unbalanced and unable to absorb terrain with my legs. I have to either get my rear end jackhammered by the seat, or put way too much weight on my hands and compromise handling.
This has really been bumming me out, because I'm wanting to do more endurance riding, but spending more than an hour or two on the bike has my wrists and hands protesting. Has anybody else experienced this with the trend of steeper seat tube angles? I thought maybe at first I just had to get used to this new position and build some core strength, but after a couple of months I feel like the pain has only grown worse. Is the seat angle really the culprit? Could an offset dropper post help? Or do I need to think about finding another bike that might fit my proportions a little better?
