1 - 13 of 13 Posts
· Registered
I seem to be unable to remove my Carbon seat post. I want to be able to do it without braking the tube. at this point, I have applied manual force. I wanted to change my seat post because the rail clamp grooves are beyond functionality. I have initiated a restoration/resuscitation project in order to share my success or failure but in the meantime, the seatpost has to go although unable to remove. At this point, I have even created a tool to open up the frame's seatpost hole but still...to no avail. Any suggestions?
· Ride More - Suffer Less
I seem to be unable to remove my seat post. I want to be able to do it without braking the tube. at this point, I have applied manual force. I wanted to change my seat post because the rail clamp grooves are beyond functionality. I have initiated a restoration/resuscitation project in order to share my success or failure but in the meantime, the seatpost has to go although unable to remove. At this point, I have even created a tool to open up the frame's seatpost hole but still...to no avail. Any suggestions?
pics?
carbon, steel, aluminum, ti?
· Registered
Lots of previous threads on this--you can search------I had carbon frame and aluminum post and tried everything you will see---chemicals/heat/etc I finally sent my frame back to pivot and they got it out---all for free. Turned out the post had bad anodizing-----so you have the same materials I had----good luck
SInce the frame is aluminum you could put the seat post in a vice and twist it----you will see folks doing this---destroys the seat post obviously but not the frame--be a bit scary
1 - 13 of 13 Posts
