I've recently been following this thread, among others, and read a lot of reviews discussing "modern geometry", and there seems to be a lot of misunderstandings and misinformation and conflicting statements. I'm not going to claim to be an expert, but a lot of what I've been reading just doesn't pass the smell test, and some of it is just complete nonsense. What am I missing, here?
First, there is reach. Reach is the horizontal distance from the bottom bracket to the top of the head tube.
Then there is stack. Stack is the vertical distance from the bottom bracket to the top of the head tube.
Reach and stack are way more important than the effective top tube measure for bike fit. In fact, I don't even look at ETT. Stack and reach are independent of seat tube angle and head tube angle; they only depend on bottom bracket, which is where your feet are.
Easy peasy, right?
Things get weird when you throw in the seat tube angle and start saying things like "modern bikes will have steeper seat tube angles to improve climbing". That doesn't compute. Here's why....
Pedaling power output is optimized by adjusting saddle fore-aft to get somewhere around KOPs (Knee-Over-Pedal). This is relative to the bottom bracket position. I'm not going to argue whether KOPs is correct, specifically, but in a general sense, you don't want to be far off from that, unless you're only going one direction: up or down.
A steeper seat tube angle with the saddle centered on the post is equivalent to pushing the saddle towards the bars. You aren't changing reach, you are only changing the saddle position relative to the bottom bracket. If I move to a bike with a steeper seat tube angle, I'm going to move my saddle back to maintain the same fore-aft position relative to the bottom bracket.
A bike with a steeper seat tube angle does not climb better. Sure, with your saddle moved forward relative to the bottom bracket, you might be in a better position to climb steep stuff, but then you suffer on the flats and the downhills.
Likewise, you can't reduce the reach from the saddle to the bars with a steeper seat tube angle because you should be adjusting your saddle position relative to the bottom bracket.
What am I missing?
Easy peasy, right?
What am I missing?
