clear nail polish and very fine sand paper should work but if it's not affecting the seals such that excess oil makes its way out, just leave it alone.Jman1 said:First time poster (?).
Is there any fix to a scratched stanchion?
Bikezilla said:I thought I read someone suggesting JB weld. Does anyone know if this will do the job long term?
I reckon it's not longer under warranty; right? 0.5mm x 3" is pretty big. Is oil coming out of it?Jman1 said:First of all, thanks to both of you.
What happened is that the inner spring of the seal came off and contacted the stanchion. The scratch is perfectly straight, about 1/2 of a mm wide and about 3 inches long. I love the fork and don't have the cabbage to cough up enough for a new one. And yes, it's directly above the disc brake, and yes, if you hear a horrible howl in central PA, it's me.
SCUBAPRO said:I reckon it's not longer under warranty; right? 0.5mm x 3" is pretty big. Is oil coming out of it?
Severum said:Whatever you use to seal the scratch, let it dry very thoughly.
I would use the finest sandpaper you can find and seriously take your time. Try to only sand the effected area. An fine emery board might work well.
If it takes two hours to do it right... spend the two hours. You only get out of it what you put in. Sucks the damage takes an instant and the fix can seem like it takes ages.
