1 - 5 of 5 Posts
006_007 said:
if it is rough / you can feel it running your fingernail over it I would suggest repairing it as it may cut up the seals.
repair can be as easy as some super fine wet sandpaper and lightly polishing it out. Possible will need a bit of epoxy then polishing that out.
+1
generally you just do not want to have anything raised like mentioned. if it is not raised...but a little gouged, it will probably be okay. so no fillers usually needed.
you don't want to go scuffing a huge area up with sand paper. as small a spot as you can. in the past, i have used a deep socket with various grits of sand paper wrapped around. the smooth, cylindrical sanding "block" allows you to pinpoint the paper to a small area.
good luck
mx
kellyhalter said:
bump help please
what the hell are you bumping for? we just helped you the other day! :madman:
what is your question?
i told you exactly what to do speaking from nearly 20 years experience. what else do you want to know???
are you hoping someone has a better idea than mine and the other guy?
mx
1 - 5 of 5 Posts
