Hello! This is my new ride, a spark wc nino edition!
Frameset: Spark RC WC nino edition
Fork: Rockshox RL3 (In the first lower leg service ill mount the WC stanchions/crown)
Drivetrain: XX1
Brakes: Sram level
Crankset: quarq xx1 non boost(!)
Wheelset: dtswiss xmc 1200 spline (rear non boost)
Handlebar/stem: Syncros fraser combination
Saddle: ergon sm pro
Pedals: Shimano xtr
Seatpost: Syncros something!
Tires: Schwalbe ray/ron
Well, first thing is i got some parts inside the box, like rubbers and plastic things that i really dunno where i should put them(ill upload pictures later).
Second, i got a concern about the quarq!
I mounted it and is really close to the frame. Frame is boost, quarq is not! (frame doesn't have protection there at all:madman
. I did 3 rides, first 2 rides was ok, but the third i saw some dirty marks(not scratches). So i removed the crankset, and i put the 2.5mm spacer for 89.5 frames and a 2.5mm spacer where the axle ends so it will not strangle the bearings. It looks way better now, but the bad thing is that i know that my crankset is 2.5mm to the right
Probably it would be temporary until i get a boost one, although most likely, 2.5mm does not have a meaningful difference to worth changing crankset at all!
Third, i have temporary put the universal boost adapter on my rear wheel, but cause of the 2.5mm offset in the right side, i just ordered another one for dt 240s that actually moves all the wheel 3mm on the right and adds a 6mm longer cup on the left only, plus the spacer for rotor.
You thing i must keep the non boost quarq or change it to a proper one?! Also any recommendation about a dropper post? XC/XCM use!
So far about the bike, its my first FS bike so i cant compare it to another one but geometry really gives you a feel you can go the fastest you can in XC tracks! I really like the sensitivity of SID, i think debonair indeed makes a different. My previous fork was sid wc(recently serviced) the last model before debonair and i think the newer mode is really smoother! Then is the three mode lockout, i think is a bit of cheat when racing compared to just full open and locked mode! Last but not least, fraser handlebars are the most stiff i have ever ride! While i dont like scott as a company, i disliked foil i own for two years and i also hate the most of the scott bikes design including this one(well its not ugly, but it could definitely be way better for this pricetag) i really like how this bikes works!
Drivetrain: XX1
Brakes: Sram level
Pedals: Shimano xtr
