Product Scott Genius 930 Bike
Model Year 2020
Riding Type Enduro / All-Mountain
Rider Unisex
Sizes and Geometry
S (Low, High), M (Low, High), L (Low, High), XL (Low, High) View Geometry
Wheel Size 29"
Frame Material Carbon Fiber
Frame Material Details HMF carbon, SL 6011 alloy swingarm, downtube and chainstay protection
Rear Travel 150mm
Rear Shock FOX NUDE T, DPS, EVOL, Trunnion, 185mm x 55mm, SCOTT custom with travel and geometry adjustment, 3 modes
Fork FOX 34 FLOAT Performance Air, GRIP 3, 15mm x 110mm quick release axle, 44mm offset, tapered steerer, lockout, 3 modes
Fork Travel 150mm
Head Tube Diameter Tapered
Headset Syncros Pro Press Fit E2, OD 50/62mm, ID 44/56mm
Handlebar Syncros Hixon 1.5, 7050 alloy, 12mm rise, 9°, 780mm
Stem Syncros FL1.5, 2014 alloy, integrated spacer and top cap, 6°
Grips Syncros Pro, lock-on
Brakes Front: Shimano MT520, 4-piston, Shimano RT-66 203mm rotor
Rear: Shimano MT520, 4-piston, Shimano RT-66 180mm rotor
Brake Levers Shimano MT520
Drivetrain 1x
Shifters SRAM NX Eagle, trigger
Front Derailleur None
Rear Derailleur SRAM NX Eagle, 12-speed
ISCG Tabs ISCG 05
Chainguide SCOTT custom
Cranks SRAM NX Eagle DUB Boost
Chainrings 32 tooth
Bottom Bracket SRAM DUB PressFit integrated, 41mm x 92mm shell
Pedals None
Chain SRAM NX Eagle
Cassette SRAM SX PG-1210, 11-50 tooth, 12-speed
Rims Syncros Revelstoke 2.5 wheelset, tubeless ready, 28 hole, 30mm width
Hubs Syncros Revelstoke 2.5 wheelset, Boost, 6-bolt, Syncros axle with removable lever and tool
Spokes Syncros Revelstoke 2.5 wheelset
Tires Front: Maxxis Dissector 29" x 2.6", 60 TPI, Kevlar bead, EXO, TR, 3C, MaxxTerra
Rear: Maxxis Rekon 29" x 2.6", 60 TPI, Kevlar bead, EXO, TR, 3C, MaxxTerra
Saddle Syncros Tofino 2.0 Regular, chromoly rails
Seatpost Syncros Duncan Dropper 2.0 Remote
Travel: 100mm on S, 125mm on M, 150mm on L/XL
Seatpost Diameter 31.6mm
Seatpost Clamp Standard single bolt
Rear Dropout / Hub Dimensions 12mm x 148mm
Max. Tire Size 29" x 2.6" or 27.5" x 2.8"
Bottle Cage Mounts Yes
Colors Bronze
Warranty 5 years for frames and swingarm
Weight 30 lb 10.3 oz (13,900 g)
Miscellaneous Virtual 4 Link suspension design
Adjustable geometry via flip chip at shock mount
SCOTT TwinLoc TSP, suspension-seatpost remote below bar with 3 modes and integrated grip clamp
Syncros Trail fender and transport axle included
Can use 27.5" wheels
