The first number is the length between the centers of the shock's eyes. The second number is the shock's travel. The Sweetspot uses a 5.5x1.25 shock. Now, 5.5" i2i shocks are fairly easy to find, the problem is most of them are 1" travel, so you frame will only get 3" of travel instead of the standard 3.75".
Cane Creek doesn't currently produce a 5.5x1.25 shock, though you might find some old AD-10 on eBay. If you want a new shock, check out Risse Racing. I talked with them a little earlier this year, and they can set you up with a modern 5.5x1.25 air shock. You can find them at: http://www.risseracing.com/airshocks.shtml
If you do get rid of the SID, please let me know. I'd probably be interested in it.
The Factory Suspension frame were design for a 80mm fork, so putting a 100mm fork on there will relax the head angle by about 1 degree. I think it actually makes the ride better since they had a 71.5 degree head angle stock, and with the 100mm fork it takes to 70.5 degree, which mellows the ride out just enough. I've done the exact same thing on my Homegrown hardtail.
