I just got a fox vanilla R propedal for my 4 banger and found out that the thread did not fit. So i had to tweak it a bit to get the trunion to fit the fox. Basically what i did was sand the trunion down a bit, pretty much sanded down all the thread inside the trunion and got a tight fit on the shock body. Then i ordered a extra preload ring to hold the trunion in place. I know some people may say it is not strong enough to hold the pressure, i thought about it too but i had no choice. So in order to make it stronger, i used jbweld to weld the trunion between the two preload ring on the top and bottom. It looks pretty strong to me and i took a few hard ride with it with no problem. But i will keep an eye on it before every ride to make sure everything is fine. Not sure if any of you want to do that, it worked for me. Just be sure to have a tight fit for the trunion, a fit that you need to use a mallet to tap it in. I called fox and tried to order their trunion for their fox vanilla r, but they said they dont sell it seperatly, how stupid.
