I just bought a DH/park bike that came with Spank Spike Race 28 wheels and Magic Marys. The wheels are tubeless compatible and tubeless is my preferred setup (I like running lower pressures as I'm quite light and find that the extra cush helps smooth things out).
So I took the tyres off and realised that they are the Bike Park version of the Magic Mary with wire beads. I figured these are pretty burly so they'd probably be fine run as tubeless, even though they're not strictly tubeless tyres, and went ahead with taping the rims and adding tubeless valves. When I went to inflate the tyre to seat it on the rim, I couldn't get the bead to seat. This was with me removing the valve core and using a compressor to inflate. Then I remembered that when I initially took them off I didn't have to unseat the bead, they just slid right into the centre channel, where I had a hell of a time prying them off with tyre levers and plenty of swearing!
My question is... is it normal for a wire bead tyre to not seat like that? It's holding air so far, but I haven't had a wire bead tyre in 20+ years and can't remember if they ping when they seat like kevlar beads do. My second question is... is this safe or scary? I'm reluctant to shell out for a different set of tyres as these are new, but I also don't want to crash into a tree because the bead rolled off my tyre (note that they were very hard to get back on... I had to use levers).
