1 - 14 of 14 Posts
So, I have a 2009 Team Scalpel and love the way it climbs...but every once in a while (which seems to becoming more often) I crave a more plush front end. The 110 SL SPEED just doesn't handel the bumps like a 140 RLC. Has anyone ever tried a 140/Max on a Scalpel? I am wondering how much it will effect the handling due to the headtube angle. Thoughts.
Hybrid Leftys aren't real
If you love the handling as is, like Nathan said, it will affect the HTA in a way that you may not like. It'll slacken about a degree, and feel more wandery than before.
You could also install a 2011 PBR damper in, much more tunable than your current cartridge, or, if you've never had the fork worked on, it may just be old tired, and dried out.
of course he could switch the steerer to a lefty4all and use a canecreek angleset to adjust the headangle accordingly
expensive workaround though
YB1 said:
What about the 2011 Lefty Ultra120 PBR? That should work on '09 Scalpel right??
I just looked through the Scalpel user manual today, and saw that 500mm was the maximum allowed fork length. (axle-bottom of head tube)
The Lefty 120mm has 490mm fork length, so it shouldn't be a problem.
Anyone try that yet? How much does it change the head angle?
Discussion Starter · #14 ·
I just put the RCL 140 on my Scalpel and took it for a ride. Axle to crown is 515mm. Handling is a little slower (not by much) than the 110SL but a 1/2 hr in I had a feel for it The bump response was much improved. Will report back after some more saddle time with some pictures.
1 - 14 of 14 Posts
