1 - 6 of 6 Posts
I am just finishing the build of my Scalpel 1st generation.
The rear shock is a Fox Float RP3.
I'm 110kg, what pressure should I put in it ?
At 170 psi, the sag is still very impressive. How much higher can I go ?
Discussion Starter · #4 ·
Or you could just run the recommended 25% of sag on the shock.
Pic is from the 2000 Scalpel setup guide.
Thx sp3000.
I had actually read that manual. My sag is more in the 12mm with 150psi right now, so I assume I would need to go roughly up to 225psi if I want to be back at 8mm.
Is it safe to run 225psi on a Fox RP3 ?
1 - 6 of 6 Posts
