RichieRich said:The non ust will work with a stan's rim strip on the new crossmax. QUOTE]
Actually, you don't need the rimstrip at all. You can Stan's non-UST tires with any UST rim without the strip....using non-UST rubber to lighten your ride is significant and not very costly. I've been doing it for about 4 years now without a hitch. If you use some lighter tires (around the 500gm range) you can knock a good 3/4 lb of rotating weight off your ride compared with UST tires.....mmmm delicious! :thumbsup:
