i know both companies utilize basically the same technology, but from what i've read there are some slight differences. I just wondered if anyone knew of any other differeneces that may exist. apparently intense's bearings are press fit into a cnc machined cut linkage plate. they use diff. tubing which is apparent, but i was concerned more wiht just the vpp. do they use the same bearings, are the axle paths exaclty identical, is either one stiffer than the other, questions like that. i'm wondering if intense may start incorporating some of the hydroformed tubing as well into its frames. thanks for input.
