Kenda Small Block 8 2.35 (725 grams) vs Schwalbe Nobby Nic 2.25 (607 grams) or Schwalbe Rocket Ron 2.25 (400+ grams)
Bike: trail (Scott Genius)
Rider: weekend xc rider (not xc racer)
I have been using my NN that came with my trail bike and I really like how they feel. It has a lot of grip for climbing, descending, cornering and braking. It also has a low rolling resistance on both on/off road but I noticed that some of the guys that races their XC bikes, uses Rocket Ron or SB8 (locally). I was going to buy the RR (400+ grms) but it looked narrow compare to SB8 and since I've seen more guys riding on the SB8, I decided to buy the 2.35 SB8 DTC to give it a try, not knowing that it is 100+ grams heavier than my NN and 200+ grams heavier than Conti-Speed King (pos tires).
fyi... Conti SK= very light tires. It makes the bike feel so light when being lifted but when you ride it, it has about the same rolling resistance as NN. Also, it has zero grip!
My question is, before installing these SB8:
1) do you guys think that this will be a better tire for climbing vs NN because it has less rolling resistance or
2) will it make the climbing worse since it is 100+ grams heavier? What about...
3) return and buy Rocket Ron (lighter and a tad wider than NN)?
Please advice. Thanks!
