1 - 5 of 5 Posts
I have a Paragon (09) model frame that has a Reba SL (06) on it. Was a broken frame warranty...
Anyways, was thinking to extend it to 100mm and trying that with the G2 chassis. Any thoughts as to how to do this and is anyone running a G2 frame with a Reba SL?
For that older model it should this easy...
1-Let out air top and bottom.
2-Remove air side top fork cap
3-Remove nut from lower air valve
4-Push air assembly from bottom out of the top of fork. Some resistance from the o-rings is normal, be careful and lube the top stanchions threads. You will need something long enough, I use a wooden dowel. (oil will fall from lower leg)
No need to remove air assembly completely, once black spacer is visible stop and remove. (travel now changed)
5-Reverse above (once lower valve is close to lower leg hole flip upside down and replace fork oil as specified, then continue)
Use a torque wrench as the values are quite small and easily over tightened!
Should take 20 min the first time, then less than 10 the next.
1 - 5 of 5 Posts
