i currently have an 03 stumpjumper pro with components:
FORK Rock Shox SID Team, 80mm travel, Dual Air, external rebound adj., compression lock-out, Alloy steerer
HEADSET 1 1/8" Threadless, 3x sealed, black alloy cups, cartridge bearings, ultralight alloy top cap and bolt STEM Aluminum, 4 bolt, 7 degree rise, black
HANDLEBARS Specialized S-Works carbon riser cut down
TAPE / GRIPS Specialized MTB grip, black, double density Kraton
FRONT BRAKE Avid SD Ti, Rim Wrangler cartridge pads, lightweight compressionless housings
REAR BRAKE Avid SD Ti, Rim Wrangler cartridge pads, lightweight compressionless housings
BRAKE LEVERS Shimano M-960 XTR
FRONT DERAILLEUR Shimano M-750 XT, 34.9mm clamp, bottom pull
REAR DERAILLEUR Shimano M-952 XTR, long cage, standard spring
SHIFT LEVERS Shimano M-960 XTR, STI integrated shifter/lever combination, 9 speed CASSETTE Shimano M-750 XT, 11/34
CHAIN Shimano HG73 CRANKSET Shimano Deore XT, splined
CHAINRINGS 44Ax32Ax22A, 7050 alloy 4mm thick outer ring, 4 bolt 104/64mm pattern, Alloy chainring bolts, self-extracting crank bolts
BOTTOM BRACKET Shimano ES-70 XT, Octalink spline, 68mm shell width, 113mm spindle length
PEDALS Crank Bros eggbeater chromes
RIMS Mavic X517, 26", black, welded seam, machined sidewalls, eyelets
FRONT HUB Specialized Stout, 28 hole, cartridge bearings, 9mm Skraxle
REAR HUB DT Onyx, 32 hole, cartridge bearings, alloy Q/R
SPOKES DT Swiss Revolution 1.8/1.5/1.8mm butted, stainless steel, black, alloy nipples, 251/251mm front, 262/264mm rear
FRONT TIRE Specialized S-Works Roll-X 2.0", Kevlar bead, 127 tpi, S-Works compound REAR TIRE Specialized S-Works Roll-X 2.0", Kevlar bead, 127 tpi, S-Works compound TUBES Specialized Ultralight, Presta valve
SADDLE Specialized Body Geometry technology, leather cover, abrasion resistant sides, Titanium rails
SEAT POST thompson elite 30.9 x 410mm (cut down)
thinking of getting xtr wheelset, disc brakes and dual control levers. give me your thoughts and most bang for the buck upgrades. id like to keep optimum racing quality and lightweight, thanks alot
