1 - 20 of 69 Posts
chasing simplicity
Thought I'd start a new thread focused on pics and builds of the new SC Blur. Just built mine this week...black 'n gold, with some custom decals to change the colorway! 21.85 lbs (including pedals).
BUILD LIST:
2019 Santa Cruz Blur cc, medium
SRAM Eagle Dub XX1 groupset including bb
Light Bicycle WMXC925 wheelset, 25mm int width, I9 Hydra hubs, Sapim cxray spokes, flyweight front, standard rear, custom color decal (1393g)
Maxxis Aspen 2.25 tires, EXO/TR
2020 Fox Stepcast 32 Factory Kashima, Fit4 (no remote)
FOX Float Factory Kashima DPS (no remote, conversion by Fox)
Shimano XTR m9000 brakes, IceTec 160mm rotors
KS Lev ci dropper post, 100mm, Wolftooth Remote
Tune carbon flat bar, 750mm
Wren stem, 70mm
Cane Creek 110 headset
Crank Bros Candy 11 pedals
WTB Silverado saddle, carbon rails
Crank Bros grips
Sahmurai Sword plug kit in bar ends
Specialized Rib Cage II
Jagwire stealth shifter cable
Heat shrink
Invisiframe downtube decals, gloss black
Fox Stepcast stealth decals
Custom Blur decals
Total weight: 21.85 lbs/9.9 kg
"Trail/AM" build
OK, I'll play. Hopefully more owners post so that there will eventually be a good amount of info in this thread. I don't race XC, but wanted a light, all-around bike for everything other than DH or bike parks as I have a Nomad 3 for those. As such, apparently mine is more, uhh, full-bodied (or fat) than the OP's bike....
Yes, mine is a porky 24.91# with computer and Arundel bottle cage.
Medium frame size with custom paint and Invisiframe
Fox 34SC 120mm
BikeYoke Revive 150mm dropper post
Light Bicycle XC923 rims / I9 hubs
Maxxis Rekon 2.25 tires
Xpedo SPRY pedals
SRAM Guide RSC brakes 180/160mm
Race Face NEXT riser bar, 760mm
Race Face Turbine R stem, 50mm
ESI grips
Chris King headset
WTB Volt SL8 saddle, carbon rails
Race Face Next R crankset
BBInfinite ceramic BB
SRAM X01 Eagle group
RWC shock eyelet needle bearing kit
chasing simplicity
Discussion Starter · #5 ·
Nice! A trail slayer. Glad you went with the 34? How do you like the Rekons? Just bought a pair for the Sierras.
I spec'd a 34SC and Rekons after demoing a Blur X01 with the 32SC and Aspens. The 34SC is definitely a better fork for all-around trail riding, but I'm still not sure about the Rekons. Might go with a more trail-oriented tire for the front.
I’ve been riding mine for a couple of months now, SC 34 makes it a very versatile bike that I can grab as a daily driver and throw on lighter tires for racing. Quickly becoming one of my all time favorite bikes and I’d rate it higher than other more popular options. As common as Santa Cruz bike’s are - I don’t see many Blurs out there... I’ll post some pics later.
Blur Tr
I have a pretty out of the box Blur Tr X01 build with Reserves.
I added carbon saddle, 9point8 Fall Like R dropper, XTR pedals, Dave-O carbon cage, ESI grips (work well with twist lock), and change out tires based on trails.
Bicycle tire Tire Bicycle frame Wheel Bicycle wheel rim
It is hugely more versatile than some of the XC bikes I have had in the past (Like Epic's) and I do not feel much downside either.
Solid bike.
chasing simplicity
Discussion Starter · #10 ·
Yep! I think my one gripe about the bike is how the cables are handled...something inelegant about how they have to bend around the bottle cage. But that's probably just being nit picky.
My new XC Race Bike
Bicycle tire Bicycle frame Tire Bicycle wheel Wheel
Frame: XL CC
Fork: Fox SC 34 120 remote
Crankset: Sram Dub XX1 175mm
Power meter: 4iiii Podium Dual sided
Chainring: Wolf Tooth Camo 34t with blue spider
Chain: XTR 9100
Shifter: XTR 9100 12 speed
R. Der. XTR 9100 12 speed
Cassette: XTR 9100 10-51
Brakes: F&R XTR 9100 Race
Rotors: F&R 160mm Shimano RT 86 ice tech
Rims: F&R Nox Composites Skyline 28h
Hubs: F&R DT Swiss 240s Boost ISO six bolt
Spokes: Sapim C-xray
Nipples: DT Swiss Proloc Hex
Valve Stems: Speed Evolution Blue
Tires: F&R Kenda Saber Pro 2.2x29 TR
Bottom Bracket: SRAM Dub
Headset: Can Creek AER
Stem: Enve 55mm Mountain 31.8
Bars: Enve M6 780mm 31.8
Grips: Ritchey Superlogic
Seat Post: Ritchey Superlogic 350mmx31.6
Saddle: SQ-Lab 611 Race Carbon Rail 15CM
Garmin Mount: K-Edge gravity Cap
Bottle Cage: Arundel Carbon side load
Chain Guide: OneUp bottom bracket mount
Pedals: Xpedo M-Force 8Ti
22.19 pounds
I will look for you. I am John Molloy. Your bike is the blinged out Blur with Gold highlights. Should be able to find you. i will be in Tahoe on Thursday. I should be pre riding the first part of the course on that day.
chasing simplicity
Discussion Starter · #18 ·
21 Rocky Mountain, GT LaBomba DJ
Here is mine. Mostly stock Blur CC X01 TR. The few changes I've made so far have been to extend to the SC34 to 120, replaced the TwistLoc after two failures with the Fox remote, changed out the grips to ESI Chunky's, changed the dropper to a Transfer during the remote change, changed the front tire to a Ardent 2.4.
I am considering sending the shock into Fox to have the tune changed and the remote removed from the shock. I really don't think the bike needs a remote for my riding style and area, simply flip the lever if needed.
chasing simplicity
Discussion Starter · #20 ·
Same here on the rear remote. Sent mine in to Fox. Took a couple weeks. Nearly everything I ride in southern Cal is climb then descend, little if any flow trails or xco style courses. Plus I like the “trail” setting on both fork and shock.
1 - 20 of 69 Posts
