G'day team
. It seems that a common solution to the problem of under performing brakes is to sand the rotors. What grade or grit of sandpaper is the best for this task?
The front J5 on my Trance has okay power but feels very "wooden" towards the end of a stop. The rear J5 felt good and was very powerful but I accidently contaminated the pads with chain lube
. Will sanding the discs possibly help in these situations?
I did not directly drop chainlube on the rear disc, but the disc ran through the pads about 2 or 3 days after I contaminated them. Should I also buy a new rear disc, or will sanding be the best option?
