Hoadley, did you also ask on Get Satisfaction?
Basically the settings are for two shock lengths which will alter the travel between 4 and 6". The lower holes are for the shorter and the upper are for the longer. The various holes for the two lengths then alter the head angle/bottom bracket - the higher the position the more lax the head lower the bottom bracket.
Hope that helps.
Hope that helps.
