The only Shimano hubs for 20mm are centerlock so if your Deore hubs are 6 bolt...look at something else. The Deore 6 bolt hubs have pretty large diameter flanges so a 20mm hub may not necessarily be larger. You don't need to spend a lot on a front hub...they're only a shell and bearings (20mm don't even really have an axle). The Sette hub from Price Point is more than significant.
Though the two hubs (Deore M525 and Sette 20mm) have slightly different dimensions...putting them into a spoke calculator comes out with basically the same spoke length...so you should be able to do a direct swap.
