I am experiencing the same problems xcguy has had with his Elixir R's.
Formula Oro K18's
Here is my situation:
Vassago 16" frame SS/w track ends. I was running Avid BB7's with 160 rotors without any problems. Thought I would upgrade and purchased a set of Formula Oro K18's. 180 Front rotor/160 rear.
Did the install using Formula instructions and torqued all hardware to spec's carefully. I started with sintered pads. The front brake works great but the rear will produce an extremely loud hmmmmm and vibration up through the seatpost under hard braking just before I lock the wheel.Under high speed, modulating the brake works a bit but when I need more brake, the hmmm and vibration begins. I changed the rear pads to organic and I still get the vibration. Did multiple caliper adjustments and just about everything discussed in xcguy's thread. I even tried wrapping a strip of innertube on the left side seat stay with no success.
I also took one link out of my chain which moved my wheel forward a bit thinking that might change things...no dice. So tonight I was test riding and while moving at high speed, I reached down and just put my thumb and forefinger on my left seat stay and braked really hard and there was no noise or vibration at all!
I did call Chris @ Formula right after I did the install and he gave me some recommendations and also said give it some time to set in. Well,I have got at least a dozen rides on these and nothing has changed. It is beginning to make me crazy. I find myself laying in bed thinking "what if I try this".
I know these brakes are factory bled but I am considering doing a bleed as I noticed the inboard piston isn't protruding as much as the outboard and I have very little clearance between the rotor and the pads although the pads are not rubbing the rotor when I spin the wheel. Possibly some air in the lines at the caliper? Don't know.....
The brakes work really well other than the vibration. Wondering if I should go 180 rotor rear with mount?
Tone.
Formula Oro K18's
Tone.
