1 - 20 of 25 Posts
Seriously ?
Discussion Starter #1
Every time I go for a 3-4 hour ride with the usual Norcal hammerheads (and when I do a long solo ride) the outcome is invariably the same: a whooping headache starting about 10-15 after I finish the ride.
No cramps, no exaustion, I finish the ride just fine. But after a few minutes I'm rushing for the Ibuprofen.
At first I thought the obvious, dehydration. However after increasing the water consumption (usually 3 liters 50/50 water and gatorade for a 3-4 hr ride) the problem persisted. I actually noticed It got a bit worse when after the rides I drink some more water.
A couple of days ago I was reading an article in this magazine where the author comments about a very common problem that affects outdoor enthusiasts and endurance athletes - Hiponatremia, the low levels of sodium in the blood. He said quite a few people are rescued every year in places like the Grand Canyon not because the go for a hike with little water, but because the drink too much of it and dont replace the salts.
Although the causes are not yet fully known, it is possible that as you loose water/salt, replaces with water only (even drinking isotonics) and the blood get diluted it affects the osmotic balance of your cells, they start absorbing more water and swell. This may cause the brain to swell and you may experience headache, dizziness and in severe cases, seizures.
It is interesting that it is common to see many recomendations about consuming enough water, while the salt loss is somewhat less important, "you only loose a bit" I've read in many places. Probably these reccomendations are not taking into account long, intense activities. According to this guy (http://www.rice.edu/~jenky/sports/salt.html) it is very common to endurance athletes finish competitions intoxicated with too much water and very low sodium in their blood (the other ones not in this condition are dehydrated).
Isotonic alone may not cut it for everybody (it certainly does not seem to be enough for me). It would take about 74 ounces of Gatorade to give you 1g gram of salt. When I look at my helmet straps totally impregnated with salt crusts after those rides it makes me wonder.
So, morale of the story, this stuff seems to be more important than it looks (at least in my experience).
I'll get a bag of pretzels for my next ride and see what happens.
Gui
More Chasmism
Hyponatremia
We see hundreds of cases of dehydration and/or heat exhaustion through the Moab ER each year. We also see several cases of hyponatremia (low sodium). I know of two cases which resulted in expensive ICU stays in Grand Junction for no other reasons than poor salt intake coupled with excessive activity and massive free water ingestion. Seems like the prime people who suffer from this are those with high blood pressure and therefore follow a salt-restricted diet. Such people must adjust the salt intake to meet the demands of exercise: which depletes salt through continuously evaporating sweat.
The other interesting thing about hyponatremia is that the RAPIDITY OF DECLINE of the sodium level determines the severity of symptoms moreso than absolute level to which the sodium falls. In other words, a person with a sodium level of 130 (though barely low) may be severely neurologically impaired if that level was reached very quickly, whereas a person with a level of 115 may not be symptomatic at all if that level were obtained over a matter of weeks or months. There is probably no greater way to RAPIDLY deplete your sodium level than to exercise vigorously in a hot, dry climate while chugging free water. Salty snacks are a MUST as such (carbohydrates increase sodium absorption).
Blah, blah, blah.
hfly <-- preparing for spring season at work
Ride what you want!!
Gui
The same thing happens to me on the very hottest rides mid summer. Only IBU won't help and they can last until bed time. It sucks. I try to get as many electrolytes as possible on those hot hot days and go so far as to drink saltwater when I get home in order to restore some balance. Maybe adding straight salt to my water will fend it off. It's something for me to try this summer.
I too get those salt encrusted helmet straps and even a fine layer of salt all over my skin. I feel your pain, and I still haven't found out how to get ride of those headaches.
Salt? Why, Yes!!!
This is very interesting. I am also a sweater (compared to my counterparts). For example, just after this morning's ride I removed my helmet only to see a about a cup of sweat pore out of my dew rag and helmet pads. I also have the salt encrusted on all my apparel. Anyways, I've been told many times to restrict my salt intake and I am glad I have not done so. I use a essential mineral concerntration in my water, one teaspoon will make a cup of water equal to seawater.....but I use only drops in approx 70 oz. Anyways, I feel my body absorb it and it seems to work for me.
I gained valuabled insight on this thread...thanks, Steve
Yummy
That said, most energy drinks like Gatorade and Powerade are pretty high in both sodium and potassium salts, aren't they? My understanding is that if you eat a bit and drink some of these drinks, you should be okay.
Kn.
Old roadie trick...
Put a bit of Morton's Lite Salt in your water bottle. Experiment with the amount. When you get it right, it actually makes the water a tad sweeter. Please note, I said Lite Salt.
Code Burr
me too
Oh man i've been dieing from those headaches all year.
I even posted something about it in the training forum,
but no one diagnosed it correctly. I thought it had something to do
with salt since I hydrate like a mofo and always find a thin layer of
white salt everywhere in my helmet. I'm wondering what the best
supplement or snack might be. I have tried taking a bag of pretzels
with me and munch them in between rides but I dont think thats enough.
I may try a bag of beef jerky, it makes your breath stink like hell but has a
ton of sodium in it I think. How do the gels rate for sodium and electrolytes?
I'm not really a fan of manufactured nutrition like that but if it helps its worth
a shot.
Fart smeller
Tell us what parts you're using.
You should try...
...the Mojo bars from Clif. When I first ate one, I was startled by how salty it was. If the lack of salt is your prob, maybe these would help. Plus, they taste pretty damn good.
fp
Jed Peters
One bottle of water with full lemon squeezed in, pinch of salt (2 shakes) and 2 teaspoons of sugar per hour in hot, one every 2 hours if it's not hot.
That's what the majority of the TdF riders use in the pro peleton. Of course, they have guys bringing them the fluids too. Gatorade, cytomax, gu, clif bars, power bars etc. are too hard on the belly to be taken for more than an hour ride.
My doc recommends eating real food on rides at hour 2 and ever hour thereafter. Last hour have your fake sugars for the quick bursts.
yes! salt very very good to me
I put a little salt in my 100 oz camel back with a little lemon.....in the summer I add one 20 oz bottle of gatorade with extra salt added to it. Taking a few swigs here and there really helps me during and after the ride.
Seriously ?
Discussion Starter #11
fp
Sounds interesting Gary, more expensive than pretzels but worth a try.
George, I'm curious to find out what would be the appropriate replenishment rate, or at least how many grams of salt a rider loses in a situation like that. K'endo, by By providing only 1 gram per 74 ounces (check the nutrition facts table) I think Gatorate may be falling short if you are loosing too much salt.
Gui
Banned
Salt is just one part of the equation. There are other eletrolytes in your system that need replenishment. Also, your symptom spiff is kind of strange, usually it's an extreme muscle cramp that is the classic symptom. I've done this before, and in fact it was during an activity where I was sucking down water from a camelback like there was no tomorrow. I simply didn't have any salt and a few minutes after resting I tried to get up and my legs cramped up and "siezed". Your headache may have something to do with sodium chloride...and then it may not. It's definitely worth a try to take something on a ride that is salty, and really it's what most people should do.
I agree with what everyone else has said
and will just ad 1 thing ENDUROX! I've tried everything and it's the only product that I really can tell a huge differance. FYI, This is a recovery drink.
mmm.... salt...
I rode a road ride called the "Hotter'n'Hell" last summer in Wichita, TX. Only did the metric century and it was about 105* or so by the time I finished. I kept well hydrated and had some of the snacks in the rest stops and power bars. After my post ride nap, I went out for dinner and I couldn't eat enough salt. It's a good think I like salt, because I just couldn't pour enough on my taters. I knew what was happeneing, but the strength of my body telling me what I needed really surprised me.
"Ride Lots" - Eddie Mercx
not discounting any of the other informative posts
because everybody seems to be providing very accurate information.
but......
I used to get a terrible migraine type headache after any king of long ride or high output event such as a 15-20 mile race. I couldn't figure it out because I was generally fine on the shorter recreational rides and the lord knows my salt intake is just fine!
I thought it was dehydration at first but I made sure to try and drink much more before the ride (day before too) and plenty on the ride. It didn't seem to work.
Anyway, what I found was that I was riding with my shoulders to scrunched (sp?) up so I was tight in the neck area for the whole ride. After I sort of figured this part out, I began to make sure that I periodically loosened my shoulders and just tried to relax more often. The more I thought about it, the more often I did it. I still got headaches after rides for a while but I think I improved my ability to ride less tight and now I rarely will get one.
Just something else to consider besides salt intake though.
hope you figure it out.
YR
More Chasmism
Gotta Agree
I've gotta agree that the headaches do not sound salt or hyponatremia-related. I too have suffered from such headaches after long, hot rides. For awhile I thought they might be glare-related, since I never used to wear sunglasses. However, I still haven't nailed down their exact cause. They do seem vascular, like pseudo-migraines (though I've never had a real migraine to compare), and are similarly photophobic (light-sensitive).
I'll have to try the mid-ride exercises as suggested above, though the geometry of my bike keeps me from being scrunched.
Very interesting thread.
hfly
Seriously ?
Discussion Starter #18
You may be right. My headache symptom is kinda isolated (i.e. I dont get the other common symptoms such as cramps,as Jm pointed out). I'll give the salt a try and pay attention to other stuff.
Gui
Crash Gordon
I had the same problem
Gui
Headaches after the ride, no cramps. I started taking salt tablets during long hot rides and have had no problems since. I bought some empty gelcaps, filled them up with plain salt and keep them in my camebak. If I don't think I need a full tablet I just dump out some of the salt. It's a bit tough of the stomach for a minute or 2, but with lots of water it okay. For me it has worked great.
Zonic's recipe is pretty good, BUT . . .
I've been using this mix on longer rides and like it. I went to 2 small-medium lemons, 3 teaspooons sugar, one teaspoon salt, all in a large (28oz) water bottle. Tastes pretty good, actually, and leaves me feeling a lot better than on just water and snack/energy bars. I have tried some of the mixes, like Accelerade, but I found these were hard on my stomach. This more natural mix has gone down easy.
Hey Spiff, could the headaches be from who you are riding with? :p
1 - 20 of 25 Posts
