Jenson exclusive bike builds
Choosing the perfect road bike, mountain bike, gravel bike, or any bike takes a lot of time. Pouring over spec details to find the right brand, build, and price that fits all your needs takes a lot of work. We know this because we go through the same exact emotional roller coaster when it comes time for each of us here at JensonUSA to shop for our new bike. We also know that you may have your heart set on a particular brand such as Ibis, Evil, Banshee or another great bike or frame but the component spec may need a little tweaking at times to make it perfect. JensonUSA exclusive builds are built with some of the best brands in the bike industry using handpicked parts that our product team spec with the aim of delivering bikes that are uniquely tuned for what JensonUSA customers have asked for.
Kona Hei Hei
With the Kona Hei Hei, You get all the speed and climbing prowess you would expect from a XC bike, but when it's time to point this bike downhill, you'll realize it' so much more. The Kona Race Light Carbon is lightweight but strong as all get out. You will never feel like you need to tiptoe around while you're riding the Hei Hei.
The Kona Fuse suspension platform with RockShox Monarch rear shock provides efficient pedaling while remaining plush through the chatter, and then really starts to shine as the bumps get bigger. The 120mm RockShox Reba upfront will smooth out the roots, and gobble up gnarly rock gardens. With the wide range of gearing that SRAM GX Eagle provides, you'll find yourself enjoying the benefits a 1x drivetrain more than ever. 29" wheels are big enough to supply that roll over anything feeling while remaining nimble through tight switchbacks and technical sections. Keeping it all under control are the SRAM Guide brakes.
The Hei Hei Trail is an unrelenting pursuit to push the limits of what a bike can do. It is perfect for the endurance racer, weekend warrior, or experienced trail rider that wants a fast, go-anywhere trail crushing machine that will turn your rides up to 11.
$3,099.99 SAVE 31 % MSRP $4,499.00
Buy Now
Banshee Darkside
Named after a local DH trail in none other than Whistler, Canada, the Darkside focuses on inducing smiles and inspiring confidence through its perfect blend of stability and flickability. The suspension linkage provides a predictable but lively feel, similar to what you might get from a well-designed single pivot design, but with all the benefits that come from using the KS Link virtual pivot system. The benefits of this linkage over a single pivot are that it offers optimized active braking, a tunable leverage curve, increased lateral stiffness, improved axle path for the direct actuation of the Cane Creek rear shock to reduce DU bushing rotation and friction. The result is a very supple suspension at the start of the travel, which ramps up to give a nice bottomless feel towards the end of travel while tracking, carrying speed well, and minimizing pedal feedback throughout.
$2,399.99 SAVE 50 % MSRP $4,768.71
Buy Now
Chromag Wideangle
This Jenson USA Exclusive Build is carefully designed to complement the frame and offer the best price to performance ratio. For the Wideangle frame, we went with a rock-solid SRAM GX Eagle 12 speed drivetrain. With its perfect shifts and wide gear range, SRAM GX Eagle will see you through the longest backroads and steepest climbs without pushing the price of this bike into the stratosphere. Shimano SLX brakes stop on a dime in any condition and offer low-key good looks. The RockShox fork sports a healthy 150mm of travel and keeps you on point as it gobbles up chunky terrain. Rounding out this custom trail weapon is Race Face Aeffect wheels wrapped in Maxxis rubber and a Chromag cockpit for superior control and durability.
$2,399.99 SAVE 41 % MSRP $4,100.00
Buy Now
Banshee Darkside
This Jenson USA Exclusive Banshee Darkside will arrive on your doorstep outfitted with a hand-selected set of components from our experts. It gets the reliability and functionality of the Shimano 10 speed drivetrain and a set of Spank Spike EVO Race 28 wheels wrapped in Schwalbe Magic Mary tires. A Rock Shox Boxxer Team fork with 200mm travel will devour any trail that stands in its way. Shimano hydraulic disc brakes provide powerful and reliable stopping in any condition and Race Face provides the cockpit components while an SDG Falcon saddle tops the Race Face Evolve seat post.
$2,399.99 SAVE 54 % MSRP $5,213.95
Buy Now
Ibis Hakka R7000
Gravel riding is becoming one of the most popular forms of riding. Riders on gravel bikes enjoy exploring new locations and are able to continue riding when the pavement ends and the dirt begins. The Ibis Hakka R7000 Jenson Bike is a highly versatile gravel and cyclocross bike that is loaded with features. It starts with a lightweight and incredibly durable carbon fiber frame that weighs 1000g. The frame is both 700c and 27.5" wheel compatible which means you can maximize your traction on the terrain you're riding on. The frame and fork use thru-axles which increases the handling and stiffness of the frame.
This Jenson Exclusive Ibis Hakka comes with a Shimano 105 R7000 mixed drivetrain. The shifters, front derailleur, and cassette are all Shimano 105 and the rear derailleur is Shimano Ultegra R8000. This combination is perfect for all-day gravel grinding and reliable for racing cyclocross. The cassette has an 11-34 tooth gear range which works well in rough terrain where steeper climbs are present. When you're coming down the steep hills, the Shimano R7000 hydraulic disc brakes provide the confidence-inspiring stopping power needed for long descents. DT Swiss C 1800 wheels are paired with Schwalbe G-One All-Around 700x38c tires. If you wanted to run 27.5" wheels instead, the frame will accept up to a 2.1" wide tire. If you could only have one bike, the Ibis Hakka R7000 Jenson Exclusive Bike would be that bike.
$3,199.99 SAVE 20 % MSRP $4,000.00
Buy Now
Niner RLT 9 SRAM Rival
Gravel riding has become one of the most popular forms of riding in the cycling world. Gravel bikes are able to ride on the pavement with ease while also being able to continue riding after the pavement ends. The Niner RLT 9 SRAM Rival Jenson Bike is built for the rider who is interested in taking the road less traveled. It has a comfortable Reynolds 853 steel frame with a geometry that favors comfort while also maintaining the performance aspect. The frame is built with thru-axles, racks, and fender mounts so you can easily turn this bike into a daily commuter or touring bike. With a carbon fiber fork, you'll have a smooth ride on or off the road.
This Jenson Exclusive RLT 9 comes with an expertly specced SRAM Rival drivetrain. The SRAM Rival 1 shift, rear derailleur, and crankset provide a smooth shift and is highly reliable. The PG1130 cassette has an 11-42-tooth gear range that makes climbing a breeze and makes it easy to ride in rough terrain without sacrificing top-end speed. SRAM provides the brakes with their Rival hydraulic disc brakes that provide ample braking power so you can descend with confidence
$2,499.99 SAVE 38 % MSRP $3,999.99
Buy Now
Kona Jake The Snake
With the ability to ride on the street, trails, and gravel, cyclocross bikes have become a mainstay in many cyclists' bike quivers. They are the perfect bike for riders who only want one bike because they are so versatile. The 2018 Kona Jake The Snake Cyclocross bike is a workhorse that you can race on the weekends and then commute to work during the week. It starts with a Kona Race Light 6061 Aluminum Butted frame that is lightweight and incredibly durable. The frame uses flat-mount disc brakes, has front and rear thru-axles to improve handling, and internal cable routing for a clean look and to keep the cables away from the dirt and mud. The fork is carbon fiber to reduce the vibrations from the road and dirt.
The Jake The Snake comes with a Shimano Tiagra 2x10-speed drivetrain. This includes a Tiagra front derailleur, rear derailleur, shifters, and cassette. The cassette has an 11-34 tooth gear range that is perfect for climbing while not sacrificing top-end speed. It comes with a Shimano crankset with 34/46 tooth chainrings. The Shimano Hydraulic Flat Mount disc brakes provide the excellent stopping power needed for commuting and racing. WTB provides the rims with their STP i19 rims that are laced to Formula hubs. These wheels are expertly paired with Clement MXP 700x33 tires which are cyclocross race-ready. If you're looking for a great all-around bike that can take you where ever you want to ride, then you'll love the 2018 Kona Jake The Snake
$1,199.99 SAVE 29 % MSRP $1,699.00
Buy Now
Jamis Xenith Endura
The Xenith Endura Sport features Shimano Tiagra 4700 20-speed components. Shimano Tiagra 4700 shifters paired with Shimano Tiagra 4700 front and rear derailleurs provide reliable and responsive shifting. With an FSA Vero compact crankset with 50/34 tooth chainrings and a Shimano 10-speed 11-32 tooth cassette, you'll be able to climb up any hill you encounter but still have enough to accelerate downhill. Alex AT 470 rims provides tubeless compatibility so you can run tubeless tires with lower pressures and encounter fewer puncture flats thanks to the tubeless sealant you'll have inside the tires. If you're looking for a road bike to take you to new places, this will be your go-to bike.
$899.99 SAVE 50 % MSRP $1,799.00
Buy Now
Jenson Exclusive build features components from the following companies to make each bike the best it can be.
