1 - 6 of 6 Posts
Make sure you reuse the outer chainring bolts from the Saint bash guard. The Saint Bash guard that I have needs to use the Saint chainring bolts or washers to because the hole on guard is bigger than normal. So a normal bolt will just slip through the bash guard.
XSL_WiLL said:
I think he's getting rid of the bashguard. You just need some single chainring bolts. Any LBS will have them. Or you can use spacers.
oops. I order the single chainring bolts by mistake a while back. It turned out to be good because I ran a single middle ring on my latest project.
1 - 6 of 6 Posts
