1 - 3 of 3 Posts
٩(͡๏̯͡๏)۶[$
Has anyone tried this setup before or know if it would work? It seems like it should just bolt right up but I don't know much about the new Saint cranks and if there is anything different about the bolt pattern and spider interface.
Also, does anyone know where I can buy the Saint bashguard online? When I did a search on qbike it showed that Airbomb had them for $10!!!! Unfortunately when I checked I found that they no longer stock them.
Any help would be appreciated!
What you are trying should work,i did the same with my 760 crank set but i used a e-thirteen bashguard,36t middle and 24t granny.Every supplier i have has sold out of the saint bashguard cause they were so cheap(inexpensive) so good luck finding one,i don't use the bashguard anymore and it's only been on the bike for 2 days and now it's off (don't like the low gearing,it's clear and takes a max tooth of 36 so make me an offer.
٩(͡๏̯͡๏)۶[$
Discussion Starter · #3 ·
Hey jamisxtrspeeder - I may be interested...
...PM sent
1 - 3 of 3 Posts
