1 - 14 of 14 Posts
Finally found the weights and pricing; courtesy of NSMB (link here):
Cranks/BB - 810g single or 1105g double w/ bash, $300 - $450
Brake Levers - 266g/pair, $250/pair
Calipers - 324g/pair, $275 an end w/ lever
Shifter - L 116g / R 121g, $200/pair
Rear Der - 240g short, 250g long; $185
Front Hub - 225g, $110
Rear Hub - 335g, $239 150 mm
Thoughts? A bit heavier than I would have wanted, but seems better than last year...
Slap happy crappiness
That's quite a drop in weight for the cranks/bb if that's true. What's the current model weigh? Somewhere around 1100g I think... can anyone confirm?
I may have to pick those new cranks up!
Something is up with those crank weights. The weight of a 32 tooth ring and a hollow plastic bash is NOT 300 grams.
I had heard earler that the cranks were only going to be a few (like 20) gram lighter...so I am guessing the single ring weight is incorrect.
Shimano certianly needs to offer another choice for 83mm bbs..
Living Ghetto Fabulous!
I'm not sure 295 grams in unreasonable... That new bashguard looks heavy. Factor in 30 grams for a 22t granny, another 30 for the steel chainring bolts, that leaves 235 for the bash... (An MRP party crasher weighs about that...)
I read that the cranks lost 150 grams from the previous generation. Sounds about right... :skep:
Anyone know if they redesigned the hubs?...They were my only complaint I have a complete saint group but swapped out the hubs for Hadley. Couldn't stand the cheap bearings in the hub.
Scimitar said:
Leave it to Sicklines to squash the debate... I really dig that site. :thumbsup:
Anyway, it looks like the actual weight for the arms plus a single ring would be 938 grams... (That's arms, bb, sleeve, ring and bolts.) Wonder where the 810 number came from? :confused: That's still not too bad though for 83mm cranks. I'm sure they're a better choice that Gravitylites for me. I can handle 138 +/- grams difference.
Interesting that Shimano is making their bashring the only one you can use. Thankfully I'll have an LG-1 to use with these WHEN I GET SOME... :thumbsup: :thumbsup: :thumbsup:
1 - 14 of 14 Posts
