1 - 2 of 2 Posts
I can't find value of % sag setting for front fork in instruction manual.
I guess it should be equal to rear shock at 25% .
So I set front sag = 30 mm.(guess) ,rear sag = 12 mm. (equal to manual).
Do I set sag of front fork wrong ?
Other question:
The rear shock RP2 has a little oil come out when bump 85 % of stroke
but for bump stroke below 50 % have no oil come out.
This is normal of RP2 ?
I would sag the fork in standing position. Its gonna be too soft and bob alot if you set it up while you're just sitting back. I'd set it to around 15-20% and change and change the pressure from there. With air forks it tends to be more of a touchy balance between "too stiff and is harsh" and "bottoms out alot" then with coils. As such, I wouldn't go too much by sag and I would aim more towards how it feels.
1 - 2 of 2 Posts
