This is a xpost from the Turner forum, but I wanted to solicit input from S Work crank owners. Maybe I'm missing something.
The bb (factory Specialized BB30) and crank with spacers are correctly installed. I even took it to a reputable Speci mechanic for a second opinion. Nope, not a thing wrong. Are any S Work crank users having issues with flex under extreme torque?
Here is my explanation at the Turner forum:
I have a Czar, size large, and the 2013 S-Works 175mm crank being used is rubbing the right chainstay under extreme hard pedaling. At first I thought it was the rubber boot crankarm protector, but even after cutting away the boot's inside I'm still having the inside of the crank arm touch the right/DS chainstay.
The crank and bb are properly installed. The S Works crank is a 166 or 167 factor, and there is proper distance between the chainstay and crank arm in all situations except the aforementioned in-saddle and out of saddle situations with extreme torque. I'm 162 pounds and a XC racer so it's not like I'm an insanely powerful torque monster.
I'm aware the S Works crank on a Czar combo is pretty rare. At this point I'd rather not use a Shimano crank with my Praxis conversion due to this particular Czar being spec'd as a lightweight marathon racer.
A reply pointed toward the oem BB being a flexy SRAM item. Maybe that's the cause? Kind of hoping so since it'd be an easy fix.
Thanks in advance.
Thanks in advance.
