1 - 2 of 2 Posts
Has anyone tested an s-works carbon crank with an X0 spider? Will it work? I've seen conflicting reports on this. I've seen pics that say XX spider is the same as X0, and Spesh sells an XX spider for S-works cranks but my LBS and I are trying to avoid a drawn out upgrade...
My Epic has an S-2200 crankset which is an X0. I want to replace with a 180mm set which conveniently S-works has in BB30.
I'd appreciate hearing from anyone who can definitively answer this one thanks!
E-Moderator
If you haven't gotten the answer yet, no. Totally different way of attaching the spider & in no way compatible. Specialized & Lightning sells spiders that are XX1 compatible. Wolftooth is currently out of stock on a direct mount 32 tooth & I'm hoping he will expand to at least a 30 tooth direct option.
1 - 2 of 2 Posts
