So after testing a while over the last year I’ve found myself to run 0 fork tokens on my 170 Lyrik and 2017 boxxer WC. The Lyrik after upgrading to the debonair definitely didn’t need the token to prevent bottom out anymore. Obviously I’m not the most aggressive rider but I like tech trails. I seem to use about the same travel with 1 token as I do none so that’s a little odd but when I went to 0 on the debonair it felt more controlled and less harsh however that was with an RCT3. So I’m wondering if maybe the lack of damper support was just having the spring ramp up and feeling that ramp up as harshness and now that I’m on the HC97 (and even the stock damper has gotten better) is maybe I should be putting the stock 1 token back in.
I know it’s easy enough to just try it and see which is what I’ll do I’m just wondering if my theory makes sense. So I’m wondering if I basically use the same amount of travel with 1 or 0 and I’ve only really bottomed the fork a few times ever but I’ve come to accept that not using all your travel doesn’t mean it is set up wrong (also good to hear that on the podcast with Darren) so where does the 1 token take effect? I guess I’m wondering does even 1 token effect midstroke or is that not enough to make a difference? Is there any kind of negative of running less than the stock setup, meaning like is this not something Rockshox would ever recommend going less than stock because the mid would become wallowing or is this just their stock setup as a guess of what most would use for ramp up? Without actual spring rate data it’s hard to tell where too much volume actually takes effect and makes the fork ride deeper in travel than desired.
Curious what others have finalized on their setup now that debonair and better dampers have been out for a while.
