1 - 20 of 29 Posts
i just bought a rune frame on ebay that comes with dhx coil. can anyone recommend good settings for the shock. i noticed on website (maybe they are referring to air) they list sag as real small (like 15-20%). should it be run with a normal sag like 30% with the coil? how about other settings.
thanks
tom
thanks
tom
dude i was next in line for that if it's the one from new brunswick. i offered 1300 shipped and she was waiting for you to pay. sweet deal. is it mint?
builttoride said:
Ignore the typo on the website, sorry, that was meant to be fixed. Rune can rune anywehere between 20 and 30% sag to suit your style.
Thanks for clarifying that. I was wondering if that was off some, since anything <20% sag on my Rune just felt too harsh and spikey (thought it was the shock). I am running about 22.5% sag now with an RP23 and feels pretty good for general trail riding, a little harsh in the rough though. Now knowing this, I am going to up the sag to somwhere between 25-30% and see how it rides especially since the bikes I have owned and ridden in the past I ran anywhere in between 33-37% sag.
Go for the throat
Has anyone out there went from air to coil in the rear on the rune? Has the ride improved much? I have an evlover isx 6 that just got back from service and I think I want to throw a coil on it instead. What spring rate is recommended for a 205 lb (210 lb or so w/ gear) rider doing mostly freeride? If anyone wants to go from coil to air I'm willing to trade the evolver.
I'd go with a 550lbs spring if you make the change. Think that will probably be best option for your weight.
Go for the throat
dft said:
finally got the rune! it took 3+ weeks to ship from nova scotia to san diego!
ps. JD risk, i could be intersted in swapping for air, not sure.
Cool. Let me know. The evolver works well, I just don't care much about the weight savings, and I think a coil would better suit my riding style. I'm not getting much riding time lately, so it will be collecting dust while you decide. I have yet to try this bike with a coil but my only complaints about the ride w/ an air shock are the following: To get a firm pedaling platform requires very little sag (around 15 percent) and a loss of small bump sensitivity. Running 20 to 30 percent sag yields a more plush ride but you tend to lose mid stroke and blow through the travel quite easily requiring a lot of hsc and bottom out set at 4. In my opinion, running a lot of hsc and bottom out effects the smoothness of the shock and I think I'd be better off running a coil with the proper spring where I can leave the shock settings more open. Maybe I don't have it set up correctly but that's just my opinion based off my experience.
builttoride,
Thanks for the recommendation. Is 550 about spot on for a 200lb - 210lb rider? I run about the maximum recommended sag with the air shock and I'd like to keep it in the same range with the coil. I never had problems pedaling this bike with a lot of sag so I'm looking to keep the ride plush and still be able to manage big hits. Thanks.
Go for the throat
Forgot to mention. I'm just nitpicking about the shock. You'll love this bike no matter what you run on it. It's a great design and the most versatile bike I've ridden. I'm just trying to dial it in to my taste.
1 - 20 of 29 Posts
