Hi, rubbing alsohol is used to clean rotor and brake pads , its the best way to clean your brakes, It might stop weird noises, ... But everybody here uses to clean their brakesgoat said:Help me out here you guys,
I herd somewere that if you rub rubbing alchoal on your rotor that it will stop weird noises that are common on disc brakes. Is this true or some bull crap?
GOAT
Rubbing alcohol is about 70% isopropanol and 30% water while denatured alcohol is mostly ethanol with some methanol mixed in. Methanol is mixed with ethanol so people don't drink it since it causes blindness. Pure ethanol is 200 proof alcohol.shiggy said:You want to use denatured alcohol, not rubbing alcohol.
Denatured is a solvent for shellac and for degreasing. Not to come in contact with skin.
Rubbing is diluted and may not even contain the solvent form of alcohol.
Yummy!!SCUBAPRO said:Rubbing alcohol is about 70% isopropanol and 30% water while denatured alcohol is mostly ethanol with some methanol mixed in. Methanol is mixed with ethanol so people don't drink it since it causes blindness. Pure ethanol is 200 proof alcohol.
You could but why waste it on your brakesxjbebop said:so we could substitute moonshine??![]()
I've noticed you need to do a little break-in (or burn-in) on your brakes again after cleaning them with alcohol.goat said:Help me out here you guys,
GOAT
