Hey guys, just ordered a middle child!
I do have a quick question. Im planning to build it up with a 120mm fox 34. Is this enough fork, or do you think the bb will be too low?
I’ll be running 29x2.5-2.8 tires (I change them out a lot, but that will be the average.
My riding is all XC, no big jumps but it is rocky. Also, I pretty much have to stick with 175mm crank arms (38” inseam).
I saw that hard tail party set his up with a 120mm fork but don’t know his crank length/curious to hear ride reports.
Congratz!!
Going 29, 120 should do good. What you really need to do is look at axle to crown length more so than travel. You will find that two forks, 120mm travel can have different A/C numbers. Research the forks in that range for A/C and see what works for ya.
Hartail's a shorter rider and can get away with shorter cranks. Good egg that rides like a man on a mission, he is tho'.
While Sunspot has 27.5x3.0's and a 150mm travel Pike, it makes the bike suited for the one that wrote the check. I run singlespeed with taller gears, live in the mountains, I need the torque only a longer lever can supply. As a geared bike (Sunspot has never been one) 170mm cranks are doable.
33red has a boner for short cranks... Go figure! In the regions where torque is not as needed as it is going from 7,000' to 10,000', I'll continue to appreciate climbing in a taller ratio.
