Wanna say 136...
Last season i was on 2.8 x 27.5 and i loved them.Question for you guys. I have had my Child for a while now and am on my 3rd Maxxis 27.5x2.8 DHR 2 on the rear. I keep slicing sidewalls. Trying to come up with a solution for a more robust tire. I'm thinking of dropping to 27.5x2.6 front and rear and running a heavier casing tire. The other idea I am tossing around is running it as a mullet with a 29x2.6 front and 27.5x2.6 on the rear again with a heavier casing tire. What have you guys tried. Give me your thoughts.
This season i bought a new bike with 35imm on 2.6 x 27.5 and was planning to go on 2.8 but i also loved those 2.6. So from my experience on wide rims you have lots of options to find 2.6 or 2.8 for where you ride. Each year i buy lightly used tires so if i do not like them i can just resell. You might want 165mm arms to avoid pedal strikes, for me 175 should only be for road.
Does the wider rim expose more sidewalls? What is the ID? Is the HR2 “true to size?” Is it potentially reasonable to consider a thinner ID rim? Wondering if the HR2 is not truly wide enough for the rim... Just spit-ballin here.
Yeah i understood your thinking. Either way might give a good result. I was just trying to show there are many options available to you. Last season i could get shorter arms for only 45$. Will the new wheel fit your fork? For me there was not room enough so the short arms was inexpensive and the result was fine.I was leaning toward the mullet to get the bottom bracket back up from dropping to the 2.6.
The 29er wheel will fit the fork and I have wheel already just no tire.Yeah i understood your thinking. Either way might give a good result. I was just trying to show there are many options available to you. Last season i could get shorter arms for only 45$. Will the new wheel fit your fork? For me there was not room enough so the short arms was inexpensive and the result was fine.
I've not tried them in 27.5 but I really like my new Schwalbe Big Betty 29x2.4 in supertrail casing. This new casing is probably like an exo+ or even dd. It feels really stiff even running 24 psi à 205lbs. Paired with a Magic Mary 2.6 as a front, it really is a game changer in rocky, rooty, muddy conditions compared to DHF2.5/Agressor2.5 or Dissector 2.4/Rekon 2.4. They are available in 27.5 x 2.6Question for you guys. I have had my Child for a while now and am on my 3rd Maxxis 27.5x2.8 DHR 2 on the rear. I keep slicing sidewalls. Trying to come up with a solution for a more robust tire. I'm thinking of dropping to 27.5x2.6 front and rear and running a heavier casing tire. The other idea I am tossing around is running it as a mullet with a 29x2.6 front and 27.5x2.6 on the rear again with a heavier casing tire. What have you guys tried. Give me your thoughts.
I have a solution, stop looking for the sharpest obstacle and choose your line properly! Every time a bloke chooses to ride the glass recycling center, they have the same problem even running semi-pneumatic tires...Question for you guys. I have had my Child for a while now and am on my 3rd Maxxis 27.5x2.8 DHR 2 on the rear. I keep slicing sidewalls. Trying to come up with a solution for a more robust tire. I'm thinking of dropping to 27.5x2.6 front and rear and running a heavier casing tire. The other idea I am tossing around is running it as a mullet with a 29x2.6 front and 27.5x2.6 on the rear again with a heavier casing tire. What have you guys tried. Give me your thoughts.
Does anyone know if there will be significant differences between the 2020 and 2021 MC? I'm thinking of picking up a frame and would probably snag one of the current batch (delivery Nov 30) if there won't be any radical geo changes, etc.
Glad to help.Great, thanks, Banshee. After you posted the geo I dug around the RSD site more and found the chart for 2021. Thanks again.
While it is not totally straight, it is adjusted for longer droppers.Probably looking at a straight seat tube vs a a curved seat tube. However, there is a benefit that really stands out above all and makes the V2 rise above the V1 and makes it completely obsolete.
It will be available in purple.
BOOM. Mic drop- Gator out.
Too bad I am color blind.
This it the only reason for seat tube change.The curved vs straight seat tube is probably right. One thing I noticed that might be significant related to that change is that the "Max Dropper Post Insertion Length" is now unlimited on the V2. Specs on the V1 are: Small 180mm, Medium 220mm, Large 240mm, XL 260mm.
