I did a lower fork service on my Rockshox Sektor Silver 140mm.
Afterwards, at my usual settings (medium/80psi), sag is over 50% just sitting on the bike. I can easily press the forks down full travel.
If I set compression at the hard end (Lock "#1") the fork seems almost locked as normal, for setting #2 also seems hard & about normal.
#3: now super soft & can compress almost fully. There is increased noise of air sound or squishing, louder compression sound than normal.
Strangely, now dialing back to #2 will now also be super soft & compress 50% quite easily. When earlier it was hard.
back to #1, & then both #1 & #2 will be hard again.
Very strange...
For the service, I just cleaned the sponge rings & re soaked them with RS 15wt oil. Wiped down the stanchions & seals. Re-greased the seals. Re-assembled & put the required 6ml of 15wt fluid in.
I have tried removing air & re-inflating several times over. Same problem.
Any ideas?
Here is a video of the problem:
Very strange...
Any ideas?
