Hello everyone. I wonder - is it possible to lower travel of RS PIKE DJ 2019 from 100m to 90mm?
I see three options here:
1. Using 10mm spacer on air shaft - but will be this a correct option and will be fork working correctly after this kind of modification?
2. To buy 90mm air shaft from other RS fork - Bluto has one for 26'. But will it fit into pike leg? And does it(shaft) have any differences in means of strength/durability, because Pike DJ is..well - DJ fork and Bluto is not.
3. Cut off 10mm of original air shaft - this is most hard to implement options, but I know some mechanics who did that successfully.
But this is what I see, maybe there is more simple options to do that.
