That's cool if your LBS is Fox-mad, I used to be. I understand where they are coming from. Fox makes good forks, but dollar for dollar, Rockshox makes better forks Their new forks (ie, Reba, Revalation) are solid forks, pretty stiff (32mm stanctions), and very reliable. Not that Fox aren't, they are, they are just more expensive. You will be hard-pressed to find anything bad about the Revalation. It's a smokin' fork. From what you're saying, the Revalation would be a great fork for you. The Reba is very similar, only the Revaltion gets more travel. There are higher end versions of the Reba though if you want uber-lightweight.
Well. . .Heres the Rockshox Revaltion Breakdown:
Revalation 409-I believe is OEM spec only. Soooooo, I'll just tell you about the Revalation 426.
There are 4 different versions of the Revaltion 426-
426 Dual Air-130mm travel. Still has external floodgate, you can still lock it out, just not from your handlebars. MSRP $450
426 Dual Air Poplock-130mm travel, with handlebar lockout. When you lock it out, I believe you still get 10% of the travel, so it is not completely locked out, just enough to take the edge off. MSRP-$495
426 Air U-Turn-Adjustable travel from 100mm-130mm. From what you are saying, this is more what you are looking for. Lockout, but not from the bars. MSRP-$525
426 Air U-Turn w/ Poplock-This is the WHIP! You get adjustable travel from 100mm-130mm AND Poplock to lock it out from your handlebars. Both of the U-Turn forks penalize you with a quarter pound extra weight though. MSRP-$570
Compared to a Fox fork, you get the stiffness, and more adjustablity for less money. I believe that in in the current exchange rate, event the
426 Air U-Turn w/ Poplock fits into your price range. Now go get a fork! Oh yeah, post some pics too after you put it on!
:thumbsup:
