1 - 9 of 9 Posts
· Registered
They're still in the post but I've bought a set of RS Domain forks and some Avid callipers and levers.
I've googled it but cant find much info.
My question is this, If I direct mount the Avid calliper to the RS Domain post mount what size rotor would I need?
I know that I can get adapters to use larger rotors but don't want to go too large if I can avoid it.
thanks in advance.
· Registered
I've had a few of the older Domains, they are post mount 160mm. You mention Avid caliper; if I recall those should need the CPS washers above and below the bolt even at 160m as they are offset a bit from other calipers to compensate.
1 - 9 of 9 Posts
