Doesn't the bike/linkage matter? WTF does height have to do with anything?g-t- said:riderweight 190 height 6'2" what would you set the p.s.i at for as active as possible ?
hey that's the reason why I postedjusten said:Doesn't the bike/linkage matter? WTF does height have to do with anything?
I run 50% of my bodyweight in PSI. That gives me 1.25" of sag, which is perfect, totally active for 5" of travel.
thx that was exactly what I was looking for.[]D[][]v[][]D said:typically use your body weight plus or minus 10 psi. Try 180 and 200 psi and see how it feels. But you should measure sag and sag should be 25-30% of travel.
The type bike it's on will significantly affect how much pressure you need (ie: the leverage ratio of the particular suspension design).g-t- said:hey that's the reason why I postedthe question. not sure what info was needed to determine the p.s.i.
this IMO is the best jumping off point because alot about the shocks performance has to do with the application.g-t- said:riderweight 190 height 6'2" what would you set the p.s.i at for as active as possible ?
agreed, sag is the best way to setup the shock. 25% is a good starting point.jrm said:this IMO is the best jumping off point because alot about the shocks performance has to do with the application.
isn't your rebound too slow? i tried this shock on a monopivot with variable leverage ratioscheckler said:I weigh 153 lbs. and ride a single pivot(heckler)- I have about 125- 130 lbs of air in mine. It is a great shock, imo.
understand that leverage ratio stuff. The rebound can be adjusted- there are 9 settings for the rebound. The important thing is to set the sag properly. After that you adjust the rebound to your personnel preference. With the way I have mine set up I am using 97% of the travel- that is efficient. As I had mentioned, different bikes have different suspension designs, this will effect how much air pressure is required for each individual rider. If you are using almost all the travel you have it set correctly.30x26 said:isn't your rebound too slow? i tried this shock on a monopivot with variable leverage ratio
1:2.9-2.7-2.5 . in the 1:2.9 position i inflated to 130psi and rebound seemed pretty slow,
in 1:2.7 and 1:2.5 it was unusable on fast dh.
in my opinion isn't the right shock for who needs less than 135/140psi to get suggested sag.
when inflated to 125-130psi my rp3 was quite slow even with rebound in the fastest position.scheckler said:i do not understand that leverage ratio stuff. The rebound can be adjusted- there are 9 settings for the rebound. The important thing is to set the sag properly.
do not ride the same bike and I do not think we weigh the same. If you do not like the way your RP3 is working maybe it is defective. Have your LBS look at it.30x26 said:when inflated to 125-130psi my rp3 was quite slow even with rebound in the fastest position.
with leverage 1:2.7 or 1:2.5 i needed less pressure to set the same sag: rebound was very slow.
I tested an RP3 for a couple of weeks on my 5 Spot (lent to my by a friend). I ran at 140 initially and finally settled on 145. I weigh 170 plus gear. The RP3 worked great. It's an excellent shock. It also seemed to have a good range of rebound.30x26 said:isn't your rebound too slow? i tried this shock on a monopivot with variable leverage ratio
I'm still playing around with settings, but 155-160 psi gave me 3/4" sag. I am 202 lbs, 5'8" (does not matter) and have generally an additional 7 lbs worth of Camelbak juice and equipment on my back. I may go to 165 psi. I also found that I needed to crank the AVA up to level 3. I was running too low psi and found to bottom the shock on any lower AVA amount.g-t- said:riderweight 190 height 6'2" what would you set the p.s.i at for as active as possible ?
I am now up to 190 psi on this shock. Anything less and it is too compliant and the Pro Pedal doesn't even seem to work due to being set so plush. So, I am slooking at going to 195 with AVA set at level 2. My rebound is at 7 to remedy the fast rebound with the high shock pressure. I had the AVA set at 3 for my last ride, which may be too high, causing the progressivity to 'ramp up' too quickly. I guess I'll get this shock dialled in before my next race.HPilot said:I'm still playing around with settings, but 155-160 psi gave me 3/4" sag. I am 202 lbs, 5'8" (does not matter) and have generally an additional 7 lbs worth of Camelbak juice and equipment on my back. I may go to 165 psi. I also found that I needed to crank the AVA up to level 3. I was running too low psi and found to bottom the shock on any lower AVA amount.
the '05 Fox rear shock manual says 300psi is the maximum for all their air shocks.HPilot said:Does anyone know max pressure for the RP3????
