international said:
Hello.
I've currently got an RFX 2006 front triangle with 5-spot stays. If I upgrade the stays to the RFX ones (i.e. build up a proper RFX) then would I be ok keeping the RP3 shock? What benefits would I see if I swapped to the DHX-A?
cheers
Tony
Let me know if you'll be getting rid of your 5-spot stays, I'd be interested in buying yours.
To answer your question concerning the shock, I don't think the air shock is a good fit for a 6 Pack/RFX. Going by the Linkage software, it appears that the Pack/RFX is a raising rate suspension. This means that the leverage rate starts off high and finishes lower, which translates to more force acting on the shock early in the stroke and less further in the stroke.
An air shock has a low initial spring force and somewhere deep in the stroke (depending on volume of the air chamber) it ramps up substantially.
When you put an air shock on a raising rate linkage you get a bad mix. Since the initial leverage ratio is high, while the spring rate is low, this means you will be riding deep in the stroke. Your shock will exhibit a lot of wallow.
On the upside, the shock will be able to take really big hits really well, since it ramps up the spring rate deep in the travel, while the leverage ratio on the linkage drops.
Overall, you'll have a very soft riding shock which is really hard to bottom out. DHX air is less progressive and might work better, but a lot of people riding the RFX with DHX air complained of it being really easy to bottom out. Replacing the original high volume sleeve with a smaller will make it work more like an RP3, but it still is less than ideal shock. On a raising rate linkage what really works well is a coil.
Air shocks work best on falling rate linkages. I'm not sure what the 07 RFX linkage looks like, whether it is progressive, linear, like a 5 spot appears to be, or falling.
_MK
