1 - 5 of 5 Posts
In reading the manual for an RP3, it looks like there is a need for Air Sleeve Maintainance and Fluid Service. There are instructions for the Air Sleeve Maintainance and they look straightforward. For Fluid Service, it says to use an Authorized Service Center.
Does anyone do this themselves? Or do you all send it someplace like Push or Fox.
Discussion Starter · #3 ·
crisillo said:
The Air Sleeve service is no biggie... I 'm not sure what is meant as "Fluid Service".. I have only sent a shock in for rebuild and nitrogen recharge...
I'm guessing to change the oil, like you do on a fork. Didn't know there was Nitrogen in there too.
Super Moderator
There is no "oil to change" (by the end user, I think)... the oil pouch you get with the seal kit is only for the lubrication of the chamber and eventually goes out with use...therefore a relube is needed...
1 - 5 of 5 Posts
