1 - 4 of 4 Posts
Curmudgeon
My new Mojo has five hearty rides so far with no issues until now. The Pro Pedal lever will not stay set to "on", it just springs back to off. The damping circuit works as it should when I hold the lever in position. It just won't stay put. This started just after I adjusted the Pro Pedal setting.
Have other's had a similar problem? Is there an easy fix or does the thing need to go back to the shop?
-Shif
Is that Bill rated?
Clean it.
I had this happen once and I removed the lever assembly, cleaned everything and put it back together. There was a tiny bit of sand that was interfering with the detent.
Curmudgeon
Discussion Starter · #3 ·
Fixed it
The tiny set screw in the triangular blue knob was a tad loose. This seems to have been the problem because the lever detents in both positions now. We'll see for sure out on the trails tomorrow...
-S
1 - 4 of 4 Posts
