1 - 20 of 24 Posts
I was wondering if the Mojo would benefit by using the RP23 high volume air sleeve that is currently used on the Blur LT (and I’m sure other frames that I’m not aware of). Has anyone ever tested this setup? Perhaps the ramp rate of the RP23 with the high volume sleeve would not work well on the DW link with the given compression ratio.
www.derbyrims.com
Ride it first with the stock sleave. If you have problems getting into the deepest end of travel the larger volume sleeve would make the shock ramp up later in travel and gain more deep travel.
Missing deep travel was a problem for me using the RP23, but was not a problem with the larger volume the DHX Air. But lighter weight riders using less air pressure than my 200+ Lbs weight or more aggressive jumpers than me may need the earlier progresion rampup of the stock RP23 air sleave.
Discussion Starter · #3 ·
Installed RP23 High Volume Air Sleeve
I recently installed the high volume air sleeve on my Mojo. For my style of riding it seems to be working very well. I don't do any big drops and I weigh about 155 lbs. The bike feels to be more plush and I'm utilizing more travel.
Is the high volume sleeve available at most bike shops or did you order that directly from Fox? Did you do the installation yourself and was it difficult?
Thanks,
Charlie
Discussion Starter · #7 ·
High Volume Sleeve
I was told that you might be able to purchase the sleeve directly from Fox. Installing the sleeve wasn't all that fun. It very easy to remove the old sleeve but installing the new sleeve is a little tricky since you need to compress the shock as you screw the sleeve onto the threads.
Do you need the "3/8" bolt extractor" to remove the reducers and the "breaker bar" to pull off t the air sleeve?
Discussion Starter · #10 ·
Replacing air sleeve
Didn't use any special tools to replace the sleeve. I was able to carefully tapout the bushing axle using a hammer and deep socket to support the eyelet. A bolt extractor may have been more ideal but I didn't have one.
Trail Rider
Did you notice any improvement or gain in stroke? Why did you try the high volume sleeve?
Discussion Starter · #12 ·
The available stroke does not change with the high volume sleeve. It does however as previously discussed make the shock ramp up later in the stroke. So in effect it allows you more easily utilize more of the available stroke. The drawback of the larger sleeve is that the shock becomes easier to bottom-out. It all depends on your weight and style of riding. Personally for me it works well but I’m sure not all riders will agree.
FR Wannabe said:
The drawback of the larger sleeve is that the shock becomes easier to bottom-out. It all depends on your weight and style of riding. Personally for me it works well but I'm sure not all riders will agree.
I've got one of those. It came off a SC Blur LT and is currently on my Prophet. The shock in stock form was too linear for the Prohet and bottomed out too easily. Adding more pressure just made the ride to harsh on the initial travel. I was able to tune the shock by adding fork oil into the air chamber. This reduced the air volume and made it more progressive. You need to experiment with the amount of oil to change the progressiveness of the shock.
My shock in the "tune" form is fantastic. The bike is plush, uses more travel and ramps up nicely at the end of travel.
I've done similar tuning on my 3-way 5th Element coil. Use more travel with a nice ramp up at the end of travel.
Trail Rider
FR Wannabe said:
The available stroke does not change with the high volume sleeve. It does however as previously discussed make the shock ramp up later in the stroke. So in effect it allows you more easily utilize more of the available stroke. The drawback of the larger sleeve is that the shock becomes easier to bottom-out. It all depends on your weight and style of riding. Personally for me it works well but I'm sure not all riders will agree.
I have an adjustable sleeve on my Tracer and I was able to get almost all the stroke out of my shock. Before, I was slightly shorter. I guess for lighter riders, they are able to get full stroke(travel), Maybe the DHX air might be the best bet for heavier riders. I did the propedal lever and adjustment on the stock shock(Ibis).
Negative vs Main Air Chamber
Not to question your findings, but I just came off the phone with a tech at PUSH and they told me that adding oil to the shock will not influence the volume of the main air chamber. What happens is that the oil makes its way into the negative chamber of the shock through the transfer port (gets through once you start riding) and then it stays there.
Maybe additional oil in the negative chamber helps, but it looks like you are reducing the volume of that chamber not of the main air chamber. :eek:
I am not sure what a smaller volume of the negative chamber equals to in a Fox float system, it will alter the balance of the two chambers as they are not independent ... you seem to like it. The tech at PUSH said that the shock action would be compromised ...
Interesting. I'll have to check the next time I pull the shock apart. If what you say is true I'll use a non liquid filler. I love the way the bike rides now so I'll leave it alone.
To put the new sleeve on, mount it in the frame and use the travel to compress it a bit to screw on the new sleeve.
RP23 or DHX Air
Although I haven't got my new Mojo yet, I am wondering if I should specify it with a DHX Air in lieu of the standard RP23? Or perhaps it might be a better option to simply get the high volume air sleeve first up?
I'm about 160lbs & currently ride an 06 Giant Reign. I like my ride to be pretty plush, so my rear shock (3-way Swinger) runs minimum SPV and relatively low pressure in the main chamber. Unfortunately I'm not able to demo a Mojo where I live in Oz, and I'd rather see if I can get the right shock before I leave the shop (in possibly 4-6 weeks when it arrives).
So how plush is the standard Rp23 on a Mojo? Can anyone comment based on the Reign? I like the idea that it's significantly lighter than the DHX Air, but I am not sure whether I would ride the RP23 with pro-pedal off normally, or perhaps just on the lowest setting.
I have not tried the DHX, but I installed the high volume air sleeve after about 3 weeks with the standard. It made for a significant change. The suspension is more plush, but pedaling efficiency is not effected, I increased air pressure to about 140 (from 135, I am 150 pounds to 165 dressed + zainetto), but I still get full travel. I could not be happier with the rear and I am not much inclined to go for a PUSH mod at this point ... the PUSH mod might really only benefit high speed (stutter bumps or close to stutter) and I am not sure is worth the extra-$
It seems that the RP23 with a high volume is a very good option for the Mojo: the plushness of a DHX (?) plus the option of using the platform with a simple lever flick, plus lighter weight :thumbsup:
Below is my Rp23 with the high volume sleeve, some carbon fiber vinyl instead of the Fox decals: it looks less red then in the photo ... :skep:
flow where ever you go
For the record:
I'm throwing out the large volume air can for the RP23.
The Mojo rode beautifully with the stock shock. I upgraded to the larger can to get more travel (as it was discussed here as a way to do that). However, I didn't realize that the RP23 is bottomed-out when there is still about 5mm of shaft (shock body) showing.
As _DW warns (in another thread), the shock does bottom out too easily with the big can. I don't get a bottom out sound or feeling, but can see that I am utilizing full travel (even on moderate rides).
I weigh 150-155lbs.
1 - 20 of 24 Posts
