hi, I am running a fox RP2 08 on my trek remedy which i have shimmed the highvolume chamber down a bit to make it more progressive, the problem is that i found the small bump sensitivity lacking on this shock so i pulled the air can apart and give it a clean and put some fresh float fluid back in there, but since i have done this i have found that the shock is requiring less air in the shock to get the same feel as i did before (correct sag) does anyone have any ideas as to why this would be? i have now since removed a bit of the shimming from the highvolume chamber to try and improve the feel of the shock for a while,
Thanks for your time, Tom,
