New to Full-sus afetr 10yrs on hardtail - Just picked up a SJ FSR Comp 06' - what is the best way to look after the suspension pivot points and shocks.............getting conflicting views from LBS (plural), ranging from everything is sealed, no need to lubricate between annual services to........."ah sir" need to lub pivots everyride and clean shock seals (remove and re-lub) every 8-40hrs.............what do real "owners" do for routine maintenance and if lube is used, what type (I see the specialized site mentions non-synthetic motor oil!........thanks.
